Playback Library View- Green screen
Images on my library look okay, but when I play them the playback is a green screen!
The easy thing to try is to reset the cameras by opening and closing the battery door.
Getting out a step stool to open the battery case is an unacceptable solution to this problem. Why is it happening? To re-ask. The image in library view looks good, but when clicking on play, the screen turns green. No images/no video.
Download it to ensure that it's still green. Might be some sort of issue with your app or web browser.
also try it on another computer and/or browser
Hi All
Also having this issue (well sought of) with one of my cameras. Image in the library seems fine, when playing the video it'll start out ok but them the screen (or half of it) will go green and/or the video will be distorted.
Have tried opening battery cover and closing but issue remains.
None of my other cameras seem to have this issue.
I've got two cameras. Both were recording OK yesterday. Today when I select one, or both cameras the image being recrded appear to be solid GREEN.
I am on a PC using Win 8.1 with IE 11.0.19 and Firefox 38.0.1. Today IE plays back GREEN. Firefox plays back BLACK - even captures that played back OK yesterday.
I opened the battery doors, re-sync'd both cameras, reset the base station, and powered off/on my router. None seemed like a sensible solution, but I did them anyway. Nothing changed in the configuration or location.
I need a resolution to this issue immediately.
I do get them once in a while in live stream when I first press the play button.. I never gotten' any on my recorded library but I did get a few times of distorted videos for a couple of seconds and that's it.. My speculation was maybe my internet or arlo's server was giving a hiccup since am not getting it too often and it's happening randomly out of my 4-cameras..
OK, so my saved files started playimng back OK, for about a day. They played back OK today until about 6:00 pm, then they played back GREEN again.
If there is a place on this site to open a trouble ticket it is not obvious to me?
Top right of this page, Support, then Contact Us. Or http://www.arlo.com/en-us/support/contact.aspx (same thing).
JPC wrote:I do get them once in a while in live stream when I first press the play button.. I never gotten' any on my recorded library but I did get a few times of distorted videos for a couple of seconds and that's it.. My speculation was maybe my internet or arlo's server was giving a hiccup since am not getting it too often and it's happening randomly out of my 4-cameras..
I'm randomly getting the green screen as well when I try to view LIVE feed. Really annoying. I seem to get it more though when i try to view LIVe feed at night. Any fixes??
Since this recent firmware update, I do get them a bit more now too than before randomly on my 4-cameras both live view or recorded.. One camera that has the Energizer (1500mah) battery in it seems to have a glitch more than my other cameras running a Panasonic (1550mah) battery.. I dunno' exactly if power or the type of battery has anything to do with it but that's what I noticed.. But both do get the green screen randomly.. Hopefully the next firmware update will fix this issue.. I been thru a couple of times now with these new firmware Updates and so far it hasn't been good for me.. So hopefully it might for you.. Arlo Netgear will just surprise us all with the new update next time around..
Hopefully for the good...and not more issues.
RegDawg & JPC,
Thank you for your feedback. Your feedback and concerns will be delivered to our management team. Our engineers are working diligently in improving our Arlo system for our Arlo customers. We appreciate your patience
KristynM
Arlo Support Team
I am just now finding this thread, and apparently even after two months this issue is not being resolved by Arlo. One of my cameras started doing this green screen bit, and worse than some others are talking about. Green on half the video, then it studders, and stalls... you only get a few seconds of video actually stored and the rest is a still shot of the last video frame that was saved to the server.
Yes, the batteries are fine, and my router is close in proximity to the camera (and it and the base station have been rebooted multiple times). I have a faster broadband connection, and no interference from nearby objects. I open/closed the battery and re-paired the camera and that works at best for 1-2 days before it starts all over again.
I resent the fact that little or nothing seems to be done to correct this since I'm not alone in experiencing it. These are NOT cheap cameras and were an investment. Luckily I talked several of my neighbors and coworkers out of buying them before they got stuck - but it appears I'm out of luck. Several calls to India have resulted in nothing more than pre-scripted attempts to put a bandaid on something that is apparently a larger problem that needs to be fixed.
And I'm finding this thread because of the same issues. I JUST installed the system today. At first, the video just stalled but now the playback is a black screen.
Seriously, Admin, what is the answer here? You've got 14 days before it goes back to the store.
Judi
You should get faster results if you place a trouble ticket. Call rather than use the web form since you'll likely end up in a call anyways.
