Mounting several cameras outdoors. Specs state <300' "Line of Sight". Will they work properly when mounted on opposite sides of a home or small building?
if you read the info ...300 is the max distance just like any other wifi. Distanace at max is usu line of sight or best conditions.
Building materials and things that the signal must pass thru can degrade the signal and lower the distance.
So the answer is it depends..
Thanks, but I don't need the theory. I was hoping to
hear from someone who has actually used these cameras
In the manner I questioned, and to learn whether or not they function
adequately. I was asking about using the cameras on the outside of
a typical residential home. My home is not 300' long,
and is not made of metal.
