  • 8 Replies
  • 3219 Views
Calagirl
Purchased two cameras about a year ago.  Suddenly not recording or detecting motion.  I have chatted with support, they said there is a known issue and they are working on it but in the meantime (weeks) I have no security.  How do I resolve this?? Don't know how to find the model I have either, just chose the first one in the options in order to put this message out there.
8 REPLIES 8
There's currently no outage. What are the base LeDs showing? WHat have you tried? Can you do anything at all?
It may be fastest to remove all devices from Settings, My Devices and start fresh. Let us know about the above stuff first, though.
Calagirl
The power LED is on, the internet LED is blinking and the camera connection LED is solid, the rest are off.  We have completlely disconnected and reconnected several times including restarting the base and tried making a new mode.
The Camera LED is what color - green or amber? It sounds like green.
Calagirl
Green
I think you're left with removing all Devices from Settings, My Devices and start fresh. I would also hold the reset button until the LEDs flash amber. Let the base reboot and then claim it using Add Devicee from the Devices tab. Sync the cameras. Update firmware as you go if prompted.
Be sure to note all settings, mode, rules and schedule before resetting to speed the rebuilding.
Calagirl
Ok, we will give it a try, thank you.  I'll let you know the outcome.
Calagirl
DUDE!!!  It worked, I'm back in business!!  I cannot thank you enough!!
Glad it worked!
