One of the cameras suddenly stopped responding to Live status and will give " Request timed out" everytime. It was working fine after the initial installation two weeks ago, any ideas how to resolve this issue?
Thanks in advance for any suggestions. The camera is located in the driveway and farthest away from base station but like I said it was working fine and recording on motion detection when armed.
The camera just started working again, I just checked it remotely. Did this happen to anyone and is it a recurring issue? I was going to follow TomMac' s advice but I guess it won't be necessary now but will do the procedure if this happens again.Thanks.
Open and close the battery door to reset camera
Go ito SETTINGS and use REMOVE DEVICE under that camera... bring it back as new ( resync )
Hopefully it will resolve your problem.
Thanks Tom and will let you know. I'm assuming this has happened to you.
