Check the MODE your currently using as to the camera rules .
If it's not the rules causing problems, try a power button reboot of the base
if still NG after above, you may have to remove the cameras ( setting>camera>remove device ) and then bring them back as new ( resync )
? breach ?
More info please
One motion detection on
TomMac wrote:? breach ?
More info please
one camera triggers 2 cameras in 2 vastly different locations to record.
Thanks for the help.... removed the offending device, re added it and revisited all Rules and it seems to have fixed the problem.
