  • 1 Reply
  • 2083 Views
InaPinch
Hey, does any one know how to change a security base back to camera? One of my cameras switches to security automatically. The following picture shows my devices setting. I couldn't find any info to change the security base with a alarm on back to a normal camera. Please help me out. Thank you!Screen Shot 2017-09-06 at 1.15.57 PM.png
If I read you correctly, you just want to rename the base station.  Edit the top Security Base by clicking on it and then click on Name at the top.  That allows you to edit the name as you like. Be sure to select Save at the top for the app or just go back for the web.
Edit:  re-reading this makes it seem like you think the base is a camera.  It isn't.  The base has no camera features in it.
