One camera offline
Thanks in advance
I'm not sure what the tech did to get the camera working but try this. Open the battery door, take the camera close to the base station and then close the door. Resync the camera after the door is closed for a minute or so.
I have a camera off line how to operate ?
Hi Aciambra,
Welcome to the community!
Kindly try to resync the camera that shows offline. Check this link below and follow the steps on how to resync your camera to the base station:
Resync your camera to the Arlo base station
Kindly check also the distance of the camera that shows offline if its within the range of the base station. Check this link below as reference:
How far from the base station can I place my Arlo camera
Furthermore, you may isolate the problem by swapping another camera to the location where the camera that shows offline is deployed and check if same problem occurs.
I am looking forward to your response.
Regards,
DaneA
Netgear Community Team
