I am on my second charger. Both chargers that I have are from Arlo and the system I have. They are supposed to charge 2 batteries at once. The right side of the charger is the only one that charges. For some reason, the left side doesn't charge. Is it something I am doing wrong, or is it bad luck that the left side of 2 different chargers doesn't work? Weird!
Define charger - the part that plugs into the wall or the tube that the batteries set into? If the latter, make sure you're properly and fully inserting the left side. Swap batteries around to see what happens - left side into the right and vice versa. Check the contacts to make sure they don't have something stuck in there.
I am referring to the tube....and the flat charger that the batteries set into. I did the ole unplug and replug. The right side of each style works but the left side doesn't. Thanks for your feedback.
And what about the other things I asked about?
