- 2
Contrary to what others are saying on here, my base station is showing offline on all 5 cameras and I do have all three green lights on. I was using 4 cameras without any problems, then I purchased another camera to add on. Once I added it on, I begin having trouble with it freezing up, cameras were showing anywhere from 2 to 16 new videos but none was showin gup in the library so no way to delete them, some of the cameras worked & some didn't so I did a reset of the base station, now it is offline and I do have 3 green lights.
What are the base LEDs doing? Should be 3 green ones. If not, give details.
Is this true for all cameras? If not, try swapping cameras around to see if the problem follows the camera. Otherwise, I suspect you have a bad base that will require a trouble ticket to get fixed.
Mbentleychp,
What browser/app are you experiencing this on? Is it an intermittent issue or is it always showing offline? Consider trying a different browser and/or a different device to see if you get the same behavior.
Can I be away from the base station to add it back after deactivating? Or is it best to be near the base station?
We recently went Wi-Fi with Xfinity and had to plug the NetGear base station into the main router. It show all cameras offline but still records. Any help on how to fix this problem would be appreciated. The fifth camera had been turned off because it is inside and used only when we are away. I cannot get a recordin from that camera because I can't turn it on.
The USB (furthest right light on the bottom of the base flashes amber..
The USB LED should be off. Try power cycling the base. If it's still flashing, the base has an issue - create a trouble ticket.
It could be a defective system (swap it) or it could be the display. Try both the app and a browser. The latest Android app is having issues showing cameras offline when they in fact are working. If this is the issue, create a trouble ticket to raise awareness.
It's possible that either the base is starting to have issues or something about the Internet connection is flaky. The latter could be the cable, router, modem or anything beyond. If your general Internet use works during the time when the base LED is amber, that may bring it down to a possible issue with the cable, base or router port.
You can try resetting the base using the reset button until the LEDs flash amber. Remove all devices in Settings, My Devices and then use the Add Device button on the Cameras tab to add the base and resync the cameras.
Hi, after a black out my arlo pro base and all the cams (i have three arlo pro cams) are offline. I'm not at home. I just want to observe my home as it is supposed to do. I asked my father to check my equipment and help me to unplug and replug everything. The base LED indicators are all solid green. Everything seems fine, but the iOS Apps and the web site show that everything is offline.
What can i do? Remember, i am not at home at the moment. This should not happen otherwise this very expensive equipment is very useless for me.... .
So what can i do???
It sounds like you'll need to resync the cameras to restore utility. This has been an issue for some time when a loss of power causes the cameras to not be able to successfully connect to the base for an unknown reason. We suggest using a UPS/battery backup for your modem, router and base to prevent this from happening. A 750VA unit for ~$100 will last for many hours and you can go up from there, depending on how long a typical outage is expected to last. Doesn't help you right now but will down the road.
Right now, you'll likely have to remove the cameras from Settings, My Devices and resync them.
No, you got me wrong. The entire base was offline, this is of course why also the cameras were shown as "offline".
I was able to solve the problem by setting the base to factory reset after i came home. But this is not acceptable to me. The entire network and all clients were working fine after the black out. Only arlo stopped working completely.
Of course A UPS Batery would avoid this. But i think this is a software or service issue netgear should analyze and solve... .
- 2
