It’s been a while, but I used to get notifications through the app if my hub or any of my cameras appeared to go offline. I am more concerned about intentional wi-if jamming now than I used be. Are those notifications something I can turn back on? Thanks
The Arlo app has messaging on the device card when it is appearing offline? Is this what you are referring to?
