  • 5 Replies
  • 668 Views
Charlar86
I have recently set up 4 of my Arlo Ultra 2 Wireless Security Camera cameras. I have made sure all push notifications are on, all IOS phone settings for notifications are on. I have made sure everything is updated,
however I am still not getting any notifications. I seem to be doing everything that’s recommended and I have tested the motion and the cameras themselves are working. This is the case on both my phone and my partners.  If Anyone can help that would be great .
thanks
5 REPLIES 5
What mode is the system using (check the Dashboard for the mode that's high-lighted) and then check that mode in Routines to verify there are appropriate rules in the mode for recordings.
Charlar86
So far I have used it in armed home and armed away with all rules selected on for notifications record and motion all on.
I believe it could be an issue with my WiFi’s settings blocking the signal ? If that’s something you would be aware off ?
It can't be your WiFi since the video is being recorded. My suspicion is that it's the app that generates the notification (hence the need to enable them in the phone settings for the app). However, I'm not an iOS user so can't provide any thoughts about that and the app.
@JamesC , @ShayneS , @BrookeN any thoughts?
There is some information here on settings that you might want to go through:
BrookeN
@Charlar86 are you still seeing this same behavior with the notifications?
