7 REPLIES 7
Is this a new installation?
If not, were you receiving alerts before?
Also, is this just an issue with alerts? That, is are you seeing recordings in the library?
I've had it for over a yr.
Is I was receiving them with the old app.
Yes I getting recordings, but at times NO alerts
I've logged out and back in.
Unplugged the base.
Restarted the base with the app on my phone.
On top of all that when trying to look at recordings it buffers for a longtime an at times freezes.
Unplugged the base.
Any solutions
Hey Ndnracer,
Are you using a custom mode or default "Armed" mode? Try testing on the default "Armed" mode to see if you receive any push notifications.
Default mode, always, never used custom mode...
Have you also tried reinstalling the Arlo app and rebooting your phone device to see if that helps?
