Not reading or formatting SD card
The base station won't read my SD card, nor will it allow me to format it even though it says it needs formatting. Purchased a new SD card and still the same outcome. This all started after the new update on July 14, 2025. Wouldn't put it past the company trying to force us into purchasing subscriptions.
How large is the card?
Have you tried deleting the partitions and formatting as FAT32 on a PC?
Some large cards are counterfeit, and don't actually have as much storage as claimed. There are a couple of tools in this link that you can use to check the card:
I have done all the above and the card does not format. It worked perfectly fine until the last update.
What brand is it?
