Not Getting Low Battery Notifications
  • 2 Replies
  • 1853 Views
KG1974
I have 5 cameras in my set and I am only getting a low battery notification from one of them. The others show 50-60% and then just go offline because they run out.  It’s really annoying. Can anyone help please?
steve_t
Master Master
I don't think they're going offline because they're running out. More likely  they are running out because they've gone offline. If the camera loses its connection to the base, iit expends a lot of energy trying to reconnect.
Try moving your base station a bit further away from your wifi router and/or restarting your wifi router so it changes channel. The idea being that there might be interference happening on the 2.4GHz spectrum
KG1974
Will try that, thanks
