  • 1 Reply
  • 2103 Views
ant
Mentor
Mentor
Is it me or does Arlo's web site not shows the videos? I had to use Google Chrome v50 web browser. 😞
Thank you in advance. 🙂
I think you're on your own here.  Sea Monkey isn't a supported browser although I'd think many unsupported one would work fine as long as the support Flash somehow.  If FF doesn't have a Flash substitute I'd believe that at least live view wouldn't work (I've used Android Chrome with success except for live view since it doesn't have Flash).
Basically, is there a Flash substitute that you can install?
