No internet light
  • 4 Replies
  • 6126 Views
JennaStutz
My base station is offline and there is no green or amber light indicating internet connection. I checked the ethernet cord and it is securely connected and other devices are connected to the same WiFi.
Try and reboot your router and then the base unit
JennaStutz
I've tried this and it connects for a little bit. Then I'll check it and the light is off again and it says I'm offline.
If the Internet LED is off, you don't even have a connection to the router. The only causes are 1) bad router port, 2) bad cable or 3) bad port on the base. Use a different cable and router port to determine if it's the base tha's bad.
JennaStutz
I will try that, thank you!
