No Internet light (amber or green)
  • 3117 Views
Bassguy
Just received my system today.  No internet light is visible (amber or green). The internet light is ok because all six lights lit up briefly upon turing the system on. I'm using a known good cable and known good port on my router because I used my X-box port and cable to troubleshoot.  Using a Belkin router.
I'm not sure what to do next.
Bassguy
Nevermind.  For some unexplained reason the green internet light just came on.
aiste
i`v got my cameras. Base station have just power green light. No ethernet light:green or orange. It flashes when power sours is plugs in.
Could be a bad cable or a bad port on either the router or base.  Try a different cable and port.  If the Internet LED is still problematic, you can either exchange the system at the store (if you're within the store's exchange period) or contact support and create a trouble ticket.
