No Internet connection.
cumins229,
Consider a reboot of your modem/router/Arlo base station. An amber internet LED indicates the base station is connected to your router but does not have an internet connection.
Since the Internet LED remains amber, it would seem to be either an issue with the router configuration (is it your router or the ISP's?) or a bad base. Restart the router and see if that helps. If you can access the router configuration, is it possible that you or the ISP has made a setting that's blocking access to ports 80, 443 and 123 to at least netgear.com? If it's the ISP's, you may need to get them on the phone to troubleshoot.
Otherwise, I'd create a trouble ticket. It may simply be a bad base station that can't access the Arlo servers. A trouble ticket would be needed to get it replaced.
