  • 4 Replies
  • 2414 Views
  • 2 Likes
TheWatcher24
1 of my 3 cameras will sync with base but the blue light wont light up and I have no motion detection , the yellow light wont light up during motion detection test
ShayneS
Hi TheWatcher24
Have you tried to reboot your camera by opening & closing the Battery door? You can also try and remove the camera from the settings & re add it.
TheWatcher24
Yes , neither worked, tried both several times each , I go into "motion detection test" and no yellow light, it's not detecting motion at all , and no blue light when syncing with base, tho it does synch
TheWatcher24
Thank you , I received a replacement camera today
