So far nothing but positive results all around and up to this point with this product. I installed my new Arlo 2 camera set up today, followed the instructions to the T and enjoyed all day views. Heres the problem - once night fell I went to check and see how the cameras look at night. Low and behold, the front door was camera was working flawlessly and the infrareds where working when viewed... But I noticed the back door camera was not. The camera is on and working, but the infrareds were not showing in "Night Vision" like the front door? Can anyone give me a hand with the second camera, I would love for it to work like the one at the front door if possible.
Here is a screen capture of what I see. The image on the left is camera at the front door (Infrareds on and working) - the one on the right is the camera at the backdoor (Camera is on but no Infrareds working so its pitch black)
The easiest thing to do at this point to eliminate gliches, would be to open the battery door on the camera and then close same to reset it.
That did it my friend, thank you very much for your time and advice.
Matt
Sounds like a trouble ticket would be the fastest solution.
Once or twice could be a glitch... every night sounds like a troubleticket so Netgear assists you.
Popping battery lid open didn't solve the problem.
derrickdowns1 wrote:
What is a trouble ticket
A formal request to support to fix a problem.
These forums are informal.
Need more details. Night vision is for turning the IR illuminators on to aid recording in dark places. Is it enabled in Settings for the camera(s)? If you test recording/live view at night can you see the dull red glow around the camera lens?
Swap the camera with a different one and see what happens. If the issue follows the camera and not the position, create a trouble ticket.
I am very disappointed with these cameras. First even though I have a model VMS3430, I cannot even enter this model number in the space above for entering the model. Netgear can start resolving issues with its cameras by first enabling consumers to enter the model number in the space provided for the model number.
My main issues with these cameras are they don't work. The cameras are either offline or the night vision doesn't work. It's ridiculous. Netgear advertises these cameras as having night vision. Consumers being required to open and shut the battery door every night to get night vision to work is absolutely unacceptable. My cameras are mounted about 9 feet off of the floor. I have no intention on climbing on a step ladder every night to open and close the battery doors of all of my cameras.
Netgear needs to either fix the issues with their cameras or stop selling the cameras. I would not recommend consumers purchase these cameras because unless you are buying a security camera go only secure your property during the day or you wish to try to pull up the cameras only to determine you are unable to see the images because the cameras are offline, there is no reason to invest in these cameras.
Gearcamera1,
When there is not enough ambient light, the camera will automatically enable Night Vision mode if you have this feature turned on in the camera settings. What is indicating that Night Vision mode is not working as expected? When Night Vision mode has engaged you should see faint red LEDs around the camera lens indicating that it is working.
Cameras dropping offline could be related to depleted batteries or a range/interference issue. What does the WiFi signal strength indicator show for the affected cameras?
Are you having these issues with all of your cameras or is it a specific camera(s) that is behaving this way?
Undoubtedly your customer strategy is to piss off customers so they take their cameras back to Costco!!!!!
TCavanaugh wrote:
When you push the "Customer Support" button it should take you to "Customer Support", not some far away cyberspace.
Not necessarily so.......not according to my most recent experience with Arlo tech support.
I had same issue with night vision not working. I have to say Netgear Tech Support was great.
They quickly resolved my problem, gave me an RMA within minutes and they're shipping me a new camera!
I was totally surprised by the excellent treatment I was given from a couple of very friendly and helpful people. Hopefully more Arlo users contacting teck support would get same treatment.
Paul
Congratulations on Netgear providing you the appropriate level of support.
However I can't find the $&@"@&$& Support Sceen that you were able to find. Call me an idiot if you'd like. But ANYTIME a Customer has to search for a Customer Support Button, Screen, Access Port or whatever else you want to call it and a company HIDES behind FAQ and SEARCH methods, they are cheap and have no respect for their customers. These comments are not directed at you. They are directed at Arlo And Netgear Executive Management.
Would someone like to simplify how you actually get to Customer Support? I'll change my tone once I have connected and receive the same support as Paul.
I'll bet many of you purchased a similar product for the purpose of security and to catch perpetrators. Because of the failure of the Night Vison to work properly on a brand new system I missed catching a perpetrator on Night Vision. The fact I can't get through to Customer Support adds insult to injury.
TCavanaugh:
Here's what I did and worked for me:
Bottom of this page --> Contact Support --> Bottom Page --> Give us a call --> phone #'s
Good luck!
Paul
Jguerdat:
you're right........I was using my desktop pc at the time and didn't think about page display differences with mobile copy.
Paul
Just got off the line with support. Disable pan and zoom and viola...night vision works great.
what if there is no phone number?
I agree totally. Arlo customer contact is designed to prevent communication. Very poor, counter intuitive. A vivid example of off shoreing at its worst
