Newest Arlo Apps for Huawei Smartphones
Hello... I would like to know where I can get in future The newest Arlo Android Apps (. Apk) if The play store will be closed by trump for my Huawei smartphone? Thanks for feedback
Hello @Frankie_Cayne,
To download the Arlo app (and the newest version), your device must support Google Play Store. You can read more here about the minimum requirements to use your Arlo system: What are the minimum requirements for installing and using my Arlo system?
Thanks for your reply.. But as an owner a Huawei Smartphone and Arlo Cams I might not be happy with this solution if Google Play store will be blocked... Please offer then another way to download newest Android. Apk Files
