New problem- Device offline
  • 4 Replies
  • 1897 Views
madkiwi
Luminary
Luminary
OK, finally found a pattern with ONE particular camera that is reporting "Device offline" about 80% of the time.
It is only offline for the app.
Every time I log in using a computer/browser that camera is online and working correctly. It is only offline to the app on my Pixel 3.
I can't even guess what is going on in this case...
I have turned the device off then on again. I have removed the camera and re-paired it. Nothing helps.
madkiwi
Luminary
Luminary
Forgot to mention- this behavior is limited to only 1 camera out of 4 that are being used. Always the same camera.
ShayneS
Have you tried to remove & reinstall the Arlo App?
madkiwi
Luminary
Luminary
Yes, while saying 3 Hail Mary's, turning in a circle while touching my nose.
Guess what!
Worked as well as the last 384 times...
ShayneS
Have you tried contacting customer support regarding this issue? I have attached the link here for you - Arlo Tech Support
