  • 12932 Views
Beazer
I have recently got a new wifi router.  do I need to reset and whole arlo system for it to work with the new network
steve_t
Master Master
Arlo and Arlo Pro cameras work via a base station connect by an ethernet cable connected to your router. A new router should just be plug and play
Arlo Q and Q Plus cameras connect to wifi so would need to be reconfigured unless your new router SSID and password are identical to the old router
Jlw7
Have the same issue.  I really hate these things.  They were a B**** to setup the first time.  Tried everything they suggest and nothing.
steve_t
Master Master
What problems are you having? These are some of the easiest cameras I've ever seen to set up. Plug the base into the power and ethernet and turn it on, wait for internet, hit the sync button. Put the battery in the camera and hit the sync button. The cameras appear in the app and you're good to go if you want to just use ARMED
