I’m using the new app with no plan on Pro cameras
On the old app you could “pause” your camera for up to 3 hours. Handy when you’re mowing the lawn and you always forget to rearm your cameras when you’re done.
I don’t see any option under “Standby” for a time. I’m sure it’s probably there and I’m missing it.
Does anyone know where i can do this? Or another way?
That feature is still there, but is not part of "Standby" (FWIW, it wasn't in the old interface either) . It is "mute notifications". When you use it, you will still get recordings, but no notifications on your phone or other devices.
Press the profile icon in the upper left of the app, and then select notifications. You'll find the feature there.
