Netgear base station and legacy netgear cameras
I inherited a netgear base station and cameras. They are branded netgear and I’m assuming we’re purchased prior to the company spinning off Arlo. Can I use the Arlo app with the netgear base station and cameras? I’ve tried pairing them via the app but it’s not finding the base station.
thanks for any help
Yes and If you inherited the system it is likely that the devices are locked to the previous owners account. You will likely need arlo support to unlock them unless you have access to the credentials.
