My cameras refuse to connect to the base station
  • 1 Reply
  • 1262 Views
Cissott52
You say cameras... so I assume more than one and none will sync.
Also , you don't say what camera or base model.
Anyway, normal is to reset the base ( hold in the reset for about ten secs till the front led(s) flash )
Make sure the ethernet is connected and base is online and then you can try to sync cameras outside of the app/web.
Most of the cameras will... just quickly push the base sync button ( don't hold ) and then push the camera button.
Quick led flashing blue on camera means it worked.
