I purchased the system new and for the most part, it has worked flawlessly. Upon my second battery change out, I have 1 camera that will not deactivate it's motion censor, sending numerous alerts to my phone. I have tried to reset the system, remove and reinstall all cameras and all are working except that one. can you help me?
For the faulty camera, you've done a battery pull, yeah?
What's the camera's motion sensitivity set at? Does it still get triggered if motion sensitivity is set to 20?
Make sure you're setting the sensitivity in your modes, not in the Motion Detection Test. Save as you back out.
