I did the reset again, deleted the app and reinstalled it to my phone it reconnects the hub and then it says it is trying to update. However it does not give me any device information. It never is successful in updating the hub.
@Craig7stw wrote:
My app is not showing me the alert videos
Do you have a subscription in force?
@Craig7stw wrote:
I have 4 the wire free cameras with the vmb3500 base
OK. Then you should have free 7-day cloud storage, and shouldn't need a subscription.
Can you make a manual recording while live streaming one of the cameras?
No
@Craig7stw wrote:
No
What status are you seeing on the base LEDs? https://kb.arlo.com/000039100/What-do-the-LEDs-on-my-Arlo-SmartHub-or-Base-Station-mean
Have you tried restarting the base?
The power light is solid green, the internet light is sometimes solid green and then sometimes a fast flashing green, the cameras light is green
I have tried to restart the base, I have tried a reset and still I never get the cameras to show up
After the reset - did you remove the cameras and base from the account, and then try to re-add them
Yes
What does the web browser display? Do you have another device you can test this with?
The app only shows 2 of the cameras but it doesn't find the other two. I cannot see any live video. It does not trigger and send any notifications for either camera. I could possibly try it on my tablet. At this point I am totally frustrated with the system. Thanks for your help.
When you mention resetting the base, did you perform a factory reset per this article here? I see the base is currently offline, can you bring it online for troubleshooting. https://kb.arlo.com/1057976/How-can-I-reset-my-Arlo-SmartHub-or-Base-Station
Can you power on your base station, It's off at the moment.
Are the LED lights green right now? It is still appearing as offline.
If a factory reset did not help, There is a chance the base station has hardware failure.
What could I do to confirm that the base is bad? If it is bad can I purchase just a base if so how much would it cost?
You can try a factory reset via these instructions again: https://kb.arlo.com/000039100/What-do-the-LEDs-on-my-Arlo-SmartHub-or-Base-Station-mean
You can remove the cameras from your app then perform the factory reset on the base station. If all is well you should be able to claim the base station and onboard the cameras and they be viewable on the web/App.
