model vmc3030. 2 of my cameras don't let me do the motion detection test or camera position. When a try said. Camera position and motion detection disable due to other activities happening from this cameras currently. What I need to do. one of the cameras have a low battery now and we just installed the cameras.
5 REPLIES 5
Tryrebooting the base to restart things.
Following as I have the same issue and my battery is not low
What troubleshooting steps have you tried so far? I do not want to suggest anything you may have previously performed.
Just want to say you all have been fabulous. I probably should have read up more but I got frustrated. Now I know there are always tweaks to make. I did finally resolve my problem by trial and error. Thanks for the support.
It turns out that I discovered you can't be actively using the camera if you want to use Positioning and Motion Detection. I didn't know that
