My Batteries are draining as in minutes..
We are new to Arlo and while setting up the cameras, batteries have drained down by 20%. We have set the picture quality to the lowest. Since then one has gone down another 5% at this rate, they will be dead in a day. Does this settle down? Is this normal? Even the cameras that were waiting to be installed that were indoors facing a wall with no movement have drained 20%. Very confused about this.
So far we have had the cameras out of the box for about 3 hours and not on at for some of that time.
Any ideas would be helpful.
Thank you.
Definitely not normal, specially if all cameras are doing this.
As a start I would open the doors on the cameras, login and delete them from the base and then close up the cameras and do a new install after resetting the base.
Thank you for your suggestion. We will try that in the morning.
