My batteries are supposed to
Last 4 months and they are going down to 12% after 2 months . It actually shows even lower when I am in the app
How can I get more time out of the batteries without having to recharge so often ? I just have the basic arlo not sure about model #
Spec battery life is for <5 minutes of recording and live viewing per day, on average. Can you verify that your usage doesn't exceed that?
The OEM cells use to run almost 4 months but the rechargables made it +/- to 2 months....
The rechargables only have about half the power capacity of the OEM cells
Not much can be done as much depends on usage ( as mentioned above )
