  • 1 Reply
  • 1631 Views
Arloene
My Arlo seems to have stopped recording overnight.  My recordings seem to fall in to a set time period.  The system is set to ARMED but then I noticed the schedule, while not selected was set to the hours I get my recordings.  Is the schedule interfering somehow?
Only if the schedule turns off the Mode you want to use...
The schedule itself does nothing but turn on/off your Modes at certain times.
Reset the base by using the power button ( off-on ) , let it come back online and check your schedule again and make sure the times are set correctly...
When armed, the cameras will have a BLACK "running man " above each active/armed camera. ( from live view screen - Devices )
