- 2
I am thinking of purchasing another Base Staion with 4 cameras. I have 2 questions.
1) If I attach the Base Station to my existing home network that already has a Base Station. Do I have to create a separate ID and password for the additional Base Station and cameras?
2) If I attach the Base Station to a different home network at a different geographic location. Do I have to create a separate ID and password for the additional Base Station cameras?
Hi , Can you also clarify the following.
Kit 1 : Base + 5 Cameras registered to A email account .
Kit 2 :Base + 5 Cameras registered to B email account .
Kit 3 : Base + 5 Cameras registered to C email account .
Kit 4 : Base + 5 Cameras registered to D email account .
All the Kits 1,2,3,4 have give access to each other . Can we view all the 20 cameras from 1 single app ? Is there a limitation in doing so ?
Unfortunatelly NETGEAR have never started any services in the Middle East for more than 1 year and they do not seem very intrested in doing so , so i am trying to cover my house with 20 cameras using the basic plan as the only option.
Regards
Roy
Use Settings, Grant Access from each additional account to one central account. Once the invitation email steps have been completed, all cameras will be seen in one login. Add the additional privileges so it's as close as you can get to using the master accounts for each. There are differences but it's 90% the same.
Thanks Guys for your help. Will get the purchases done and get cracking on it.
- 2
