  • 1 Reply
  • 4072 Views
Trojan
I have 3 cameras, the one facing my front garden goes off all the time.  I have turned motion detection down to 1% but it still goess off constantly.  The only thing I can see moving in the recordings is a few plant leaves blowing in the wind.  The other 2 cameras are fine.  Any ideas?
Yes....
First, reset the camera by opening and closing the battery door. then swap the trouble camera with one working fine.
See if the problem follows the camera ( put sense level back to default of 80% )
If it continues with that camera after above, go to settings and use remove device...then bring the camera back as new ( resets all to default in thebase unit too )
If still NG after, contact NG support
