  • 4 Replies
  • 7005 Views
  • 2 Likes
shaunschulman
Hi guys, can anyone tell me how I make the camera dection more sensitive, I under stand the default is 80, but do I turn it up or down to make it more sensitive to smaller movements?  The manual doesn't say which is which.
manofice
Virtuoso
Virtuoso
100% will be the most sensitive.
AnnCamas
When I move the motion senstivity off 80 on the mode page it does not set/save but defaults back to 80. I see no save button?
See the Back selection at the top left? Use that and save the rule. Depending on whether you're changing the Armed mode or a custom one, also save the mode.
AnnCamas
Thanks; I found another post after much looking shortly after posting, with the non-intuitive answer but it works 🙂
