Hi - I've got an Arlo system with 7 cameras. Some inside, some outside. I'm using geofencing, which I really like, for when I'm away from home. Is there a way I can set the system up so when I'm home at night say, all of the outside cameras can be on and all of the internal cameras off? Can 't quite figure out how to do that!
Thanks in advance!!
If you set up a new MODE, only make rules for the cameras that you want to record. Then when in the app geofencing settings in your phone, select HOME mode to be your new recording mode
Thank you!
