Modification
Is there a way to create an automatic scheduler that sends an e-mail picture from a camera, a prescribed times throughout the day?
Can the system be set up to run off of a 3G network, rather than an internet connection?
Can the system send notifications when a connection is lost with a camera?
1) Not to my knowledge
2)good question... It requires access to the internet...I would guess that a Cellular router could possibly (educated guess) be used if needed with the right hardware, tho 3g might be close to the min speed required unless a very good signal, better with 4g. Costs would be another story re data as it is on all the time.
3) No, but it will send notices when batteries are starting to fail or storage near full.
Hello Stevenperos,
You have some good Ideas for making Arlo a better product. You should post your ideas inside the Arlo Community Idea Exchange
