Battery Charge paper airplane icon
Shouldn't the paper airplane icon next to "Battery Charge" be turned on if the Low Battery Notification is turned on in the Settings/Preferences section? I turned it on there but the paper airplane is not highlighted.
Thank you
Hello John,
Sorry for the late response. To answer your question the paper airplane represents "email notifications". This option is unaffected by the low battery alert. To turn on or off email notifications click the paper airplane. The check mark right beside the airplane will either turn Green or Black. Green means that e mail notifications is activated, and you will receive e mail alerts when motion is detected. If the check mark is black, this means that e mail notifications is turned off, and you will receive no e mail notification when motion is detection. I hope this answered your question
The Arlo Team
David
