I have 4 cameras, 1 base station and one Arlo Q camera.
I had 2 cameras and recently added two more wire free. I know when I had 2 I could arm only one of the cameras and set for motion and video. Now that I have 4 wire free I set it to armed, it wants to set motion video and push notifications on all cameras. I DO NOT want that. I want one to be armed and the others not. The arlo Q works fine. So do I have to reset to factory settings, reconnect everything then will I be able to set one wire free to detect motion and record and the other 3 I can just check manually when I get a push notification? Factory reset is all I can seem to think of to do. I hope someone has a better solution.
You need to create a Custom mode.
Use search above for ...how to create mode
