Can someone please help me. My device keeps saying “I’m offline”. But I have plugged it back in and out, turned my WiFi off and on. My other devices are all fine. Can not get a number for support in the UK.
There's a UK phone number here: https://www.arlo.com/uk/support/contact.aspx
@Tmoxie wrote:
. My device keeps saying “I’m offline”. .
Are you talking about a base station or a camera? What model?
@StephenB Thanks so much for responding. It’s the Netgear base. The cameras were working fine and then one morning I came down and it says you are off line.
It's Arlo now (Netgear sold off Arlo).
What's the label on the base? There are several models of base station out there - VMB3000, VMB4000, among others.
Anyway, try support (if you haven't already).
@Tmoxie wrote:
Also, sorry it doesn’t say anywhere you need to replace the base and isn’t that change at the end of September?
You DON'T need to replace the base (unless it failed). You will need to switch to the new app. But not any hardware.
@Tmoxie wrote:
For the model I showed you
Sorry, I just didn't notice the attachment. You have a VMB3010r2. It looks like it is running current firmware (1.12.2.4_2772, released on 25 June).
Did you try the UK support number in the link I posted earlier?
