Mains power for ordinary old arlo
anyone know if you can still get a mains lead for a mk1 arlo camera?
Can you open the camera for a model number?
Referring to the base ?
The original Arlo HD camera was only powered by 4-123 cells AND did not use a power cable.
If your referring to the base unit, the base unit is power by a 12v supply to a coaxial plug with center positive.
Plug is 5.5mm ( IIRC ) and the supply needs 1.5a output
Hi
Thanks for replying. I have two - both model vmc3030.
They have a covered socket with a cap that you have to lever off in order to insert a plug.
There was never an official external power supply for these cameras. I believe there have been some 3rd party supplies but no idea how well they worked (weather sealing would be an issue) as well as whether they're still available.
