  • 1 Reply
  • 1513 Views
Theantikarma
Of the cameras that can still be purchased which ones are compatible with those domed magnetic mounts? My landlord doesn't allow drilling so I need an adhesive, magnetic option.
None are really suitable for adhesive attachment although some industrial-strength adhesives may work and still be able to remove it later. The mounts all depend on screws.
The older Pro and Pro 2 may still be available which can use the built-in magnets to stick to metal (ferrous) surfaces. The newer cameras don't have the magnets in the camera - they're in the mount - but the camera tends to be bigger and heavier.
You can be creative and come up with a solution that works for you like building a bird house that has the camera inside.
