  • 5 Replies
  • 3760 Views
ArloBirdCamera
Manual recordings go into the Library, MOTION RECORDINGS DO NOT
YES: It's armed, filters are set to show all, I get motion notifications, I get notification emails, and yes it's actually recording, I can watch the recordings on the temporary shared link in the email notifcations, which would be fine if I could download and save the videos from there, but you can't.
I uninstalled and reinstalled the app and it's updated.
Restarted and re-synced everything multiple times. No settings were changed, just one day motion recordings stopped going into the Library.
Why are motion recordings not entering my Library?
5 REPLIES 5
you don't mention ios or android and what version / device
ArloBirdCamera
iPhone 5s iOS 10.3.1
Base Station VMB3000 with Arlo Cameras VMC3030
Motion recordings won't appear in Library logging in on Firefox 48.0.2 either
First thing is to just power reboot the base ( power button or unplug ) then test again
Also check the base/cameras SW version..( found in settings/device/info).
Arlo base is 1.8.8.0-11528
cam is 1.2.10342
ArloBirdCamera
Powered off/on, re-started, and re-synced for two weeks, that's why I'm here, doesn't work
You have listed the correct updated Firmware versions for my Base Station and Cameras
Hardware version for Base Station is VMB3010r2
Hardware version for all Cameras is H7
ArloBirdCamera,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
