  • 2 Replies
  • 2928 Views
ROG54
I have an Arlo H7 and received my first low battery warning (14%).  The camera shows online but has stopped recording motion alerts and will not let me start it to get a live view.  I am 3 hours away from the camera to change the batteries.  Is there a way to bypass the warning to allow the camera to continue to functioning normally until I can change the batteries?
Thanks!
steve_t
Master Master
That's strange. Mine detects motion and records until the battery is completely depleted. Try turning the camera off and then on again in the settings. If that doesn't work, try a remote restart of the base station but obviously at your own risk in case other cameras decide to have an issue because you're miles away from home
ROG54
Thanks for the suggestions.  I tried both and unfortunately, neither of them worked.  I'll keep searching.
