  • 1 Reply
  • 3766 Views
Moll2969
Does anyone know if Netgear produces a booster? Or is there a way I can somehow extend my camera signal length? My cameras that I want to put in the back of my house have zero signal, so I can't use them. Is there anything I can do besides moving my router?
thanks!
thanks!
You can't boost the signal from the cameras, they talk only to Arlo base...
But you can;
1) move the Arlo base with a ethernet cable to a central location so all your cameras have a good signal
2) buy an upgraded service that allows more than one Arlo base so the bases can connect to the closest cameras thereby increasing area coverage
3) use a wifi extender with an ethernet port so the base can be located in a central location ( like #1 ) for best coverage as long as the extender supports more than 1Mb data transfer
