I need to purchase a longer ethernet cable for my (basic) Arlo. What type/ specs do I look for when purchasing a new cable?
For longer cables( and high speeds ), I'd buy a type 6 or 6a...
Arlo operates at 100Mb/s so a CAT5 cable is sufficient. However, the newer cables are potentially worth the extra cost so you can reuse it for other purposes later.
Thanks for the quick reply. Your help is appreciated.
