Live streaming
  • 1 Reply
  • 3198 Views
Joeybravo21
I have a 3 camera system, each camera is no farther than 50 feet from the base. When I try to check the live stream on my phone it's always buffering or not the best video quality. I'm not very knowledgable with wifi routers, but at the moment I'm running a Belkin AC750 dual band. It's a couple years old and judging by the price I paid it's not top of the line. So my question would be, with 3 cameras, should I upgrade my router? Possible to a Netgear nighthawk line? Any help would be greatly appreciated
Your router likely doesn't have anything to do with the issue. The connection between the base and camera is what's important - the router only completes the Internet connection. 50 feet generally isn't too far but it depends on how many walls, etc. there are between the base and any particular camera. What are the WiFi indicators on the cameras tab showing? They should be 3 to 4 bars and green.
