  • 1 Reply
  • 3203 Views
Saffron
My motion detector went off on and now the live feed shows is half black and the other half is a very distort image. This is on a single interior camera. No changes have been made to the app or where the camer is it just started going this on its own.
Open and close the battery door to reset the camera...then test.
If it continues, swap location with another camera( if able ) to make sure it's not the location or temp move it ( checks for interference )
Last, if continues use REMOVE DEVICE from settings and bring back as if new..this resets all in the base too for that camera....test
In the end , keep an eye on it and if it is a repeated issue there is Netgear Support in case of hardware problem
