Hi folks,
Looking into Arlo vs. Arlo Pro. Want to find out about the Arlo cameras. Can I select always free streaming but no recording at all -- to save battery life?
Also, wonder if the Arlo Pro's rechargeable batteries @ 7.2V is much higher than Arlo's operating voltage?
I'm just wondering if Arlo w/ NiteCore batteries would have any similar battery life (assuming same recording activies) compared to Arlo Pro cam's.
Thx.
You don't need to record but streaming will be an issue from both battery life as well as the length of the stream. Live view will only last 30 minutes before timing out to save battery.
Adrlo with NiteCore batteries will have similar life to the Pro batteries. I'd choose the Pro for the better performance.
