I am new to Arlo 3030 camera tecnology but see frequent adverts for a LANMU power adaptor to replace the C123 batteries. Mixed reports on the seller sites, does anyone in this communty or at Netgear have first hand experience/advice?
It's got an "okay" rating on Amazon but I don't think anyone has posted about it here. Just be aware that use of it could void your 1 year warranty if it causes an issue with your camera.
Apprecciate the warning on the warranty, I was not aware of that.
I bought a LANMU power adapter. It seemed to work but when I plugged it in it showed battery at 50% even though it was plugged in. Then I noticed that the battery would be depleated over time. Now its at 25% even though its plugged in and not really a battery. Not sure if it's working correctly or not but doesn't seem to be if the power gets depleated.
